Water Maker Question, 2nd Thread
Originally posted by Crossroads
If I wanted to build my own water maker, I would pull up to the dock in Seahawk215's back yard with a cold case of beer and discuss the project. He is much smarter than most any of us when it comes to water making.
. Thanks for the compliment Bill. Let me know when you get back to ft lauderdale we will do some fishing. The water maker companies have to worry about liability so a lot of bells and whistles are to protect them from legal action in case they were to get sick from poor water quality. A very simple system can be made to make potable water if you check the water quality and make sure the water is disinfected if stored for any period of time. Contamination will occur from somewhere else not from the water maker product.
Originally posted by pdecat
so why not just buy a pressure washer motor and pump for $150?
You could. It would work but would not last very long using seawater.
Originally posted by Billylll
Dan I know there are chemicals you can try to bring back your membrane depending on the damage. Oil damage or contamination can be reversed. Take a look at some of the chemicals available on the Spectra site they tell you what they can or can't do with the membrane.
Thanks for the lead Bill. I have no idea what's wrong this time. We arrived in the Bahamas and as a result I had to dial in a bit more pressure.
As I slowly dial in the valve and the pressure rises I can hear the vessels or membranes creak a bit. I'm wondering if it chucked a seal kit this time.
I'm really tired of the Village Marine set up and what's its taken to get installed and operational to this point and have it fail yet again.
Their staff has indicated (not this time yet) that the Bahamas water will produce less and having told them my intentions and what we wanted as productivity, they sold me the LWM300 in modular form.
It's been a dissaster and totally unreliable. We've treated this with kitt gloves and its never put out.
Dan, from what I have learned actual output can be effected by a lot of things. Among them are salinity, length of plumbing, types of pre-filters, etc.
But, I have also learned that you can nearly double the output of the system by plumbing in a second membrane module in series with the first. Nothing else is needed.
Maybe that's all you need to do to get the water supply you need.
That was what we did to get it installed. We have two 20 inch membranes in series. It's not just the poor output rate, the ppm is 500 now. They have proprietary membranes and they are going out the door. At some point I may rip all this crap apart again so I can test the membranes separately and see which one is junk this time. It has a total of about 20 hours on it and it's never lived up to expectations unless we were in fresh water.
Sorry to hijack but if you were considering component / modular I wanted to warn you. I'll end my rant now.
Not a problem. You just touched a nerve when you said "fresh water". I don't know about the brand of membrane you have, but, membranes Filmtec makes for desalination are different from the ones they make for fresh water purification. Could that be your problem?Wrong type of membrane?
1 gpm, 10 PSI? is that really going to feed a high press pump? for how long?
my concern abot manual mode if your'e going make more than a couple of gallons a day is keeping an eye on thing, keeping the pressure correct, enough water to the high press pump, etc...
i wonder how it really works in the real world.
This is tempting. From your price list it would appear I could double my output for around $200. I wonder what adding a second membrane would do to an off-the-shelf system? My natural tendency is to fear the worst.
Well, I'll just have to let you know. But, if you take a good look at the Katadyn basic units (80e) that's all they are.In fact, the schematic I am using is almost exactly the same.Plus, I am going to add a flow rate meter, that's all
As for the feed pump, I actually took that number off of a system I looked at on a Lhurs SF. Seems to work OK in that application.
You have to remember, I only have a 40 gal water tank and a 11 gal water heater, total 51 gal. Even if I completely empty it every day, which I never have, (90% of the time it's just me alone or me and the Admiral) that's not much run time to refill it.
My boat is what it is and its capabilities are what they are. So, I'm designing and building a system tailored to that and my needs. Will what I am doing work in a 35'+ boat? Maybe not. But, will it work for mine? I think so.
But, skepticism aside, I'll let you know how it works after I get it built. :)
If do that you will need both a membrane and a pressure vessel to put it in so you're looking at about $370.
Will it work? I don't know. But, if you duplicate size, type and flow rate of the one you already have, I'm NOT an expert, but, I don't see why not.
Keeping the pressure correct should be no problem. Unless the salinity of the surrounding water changes the pressure should stay stable. And you could remote mount a pressure gauge to keep an eye on it.
But I think I would go for a better feed pump. That Sureflo is only rated for intermittent duty.
I dont understand the "membranes in series" to double output comments. Shouldn’t that be parallel??
It's maintaining the flow rate at a pressure that one has to be concerned with when adding an additional membrane. As far as series vs. parallel, Village Marine was against that. I don't really follow why but I suspect it lies in the above statement. While you may have the pressure required with the regulator, you are splitting the flow rate.
Water temperature has a lot to do with production. The Spectra site gives you expected output for various water temps. I know they make a unit specifically for the Bahamas and the Islands.
the way I figure it is that in parallel the "easiest" membrane would get the most flow. When it stops up a bit the other would the pass more flow because the pressure would be higher. In series the second membrane is doing nothing if the first one did it's job but the pressure would have to be much higher.
In series they both have the same pressure since the regulator is down stream from both of them. Having previously pulled them apart and tested them to find the bad guy I know the second in line puts out less. But that is the way the unit is spec'd.
They probably found it by increased pressure (out of specs) from scaling or fouling?
Each membrane has a product side fitting on each end and one feeds into the other. Just disconnect them and flow them both into a separate cup. Check with a TDS (Total Dissolved Solids) meter and the results are quite obvious.
I'm wondering if by using two in series if they blew it with the design. I am wondering if to get 800 psi at the regulator, the first in the series is dropping pressure thus being exposed to too much.
