What ever you do get a light color. I have a FB 36 Trojan, when I first got the boat it had an off white cover and all was well. I replaced it with a dark brown cover to match the other canvas and the temp was so hot in the boat I put 1 inch blue board panels on the glass under the cover, that worked. Last year I replaced the canvas with a mesh type of cover, we can see out and have light but you can't see in nor does the sun heat the cabin. The new cover was recommended by the canvas guy, cost $250.00. The boat has a down station so I have to be able to use the glass when the weather is bad otherwise I'd have kept the blue board, but handleing 3 those big panels in the wind was tough.
I don't know if you know this boat, but the back of the cabin close out is a 10 ft. glass panel and door combination it still is a problem, we have curtains on the inside but once the heat is in, it's in, so I have a curtain that we hang outside when necessary. When I bought the boat it had a 18k btu a/c, that as big a 120 volt as you could get. Today as big as I've seen is 16.5k btu, so if I ever have to replace the a/c I will get a 16.5 and a 8-12k that should solve the whole problem.
