Windshield Canvas
mawyatt
I'm looking at getting a windshield wrap around canvas for our 2008 SeaRay 38DA. Went to Great Lakes Canvas (SR OEM) and they don't show anything for this boat. Anyone suggest a source and est cost? Any recommended local (Tampa Bay, Fl) canvas shops?
Thanks hounddog. I'm trying to lower the cockpit temperature at dock. Is this effective for your boat?
I had a double layered mesh covering made for my windshield (not canvas) so we had light, with daytime privacy. I tinted my windows last winter and have experienced a remarkable reduction in cabin temperature, and zero upholstery fade. The difference from last year is amazing, and added privacy is a bonus.
I second tinting as a way of keeping cabin temps down, works great on my boat but I don't have a lower helm or lower windshield. Regards Bill
What ever you do get a light color. I have a FB 36 Trojan, when I first got the boat it had an off white cover and all was well. I replaced it with a dark brown cover to match the other canvas and the temp was so hot in the boat I put 1 inch blue board panels on the glass under the cover, that worked. Last year I replaced the canvas with a mesh type of cover, we can see out and have light but you can't see in nor does the sun heat the cabin. The new cover was recommended by the canvas guy, cost $250.00. The boat has a down station so I have to be able to use the glass when the weather is bad otherwise I'd have kept the blue board, but handleing 3 those big panels in the wind was tough.
I don't know if you know this boat, but the back of the cabin close out is a 10 ft. glass panel and door combination it still is a problem, we have curtains on the inside but once the heat is in, it's in, so I have a curtain that we hang outside when necessary. When I bought the boat it had a 18k btu a/c, that as big a 120 volt as you could get. Today as big as I've seen is 16.5k btu, so if I ever have to replace the a/c I will get a 16.5 and a 8-12k that should solve the whole problem.
I tinted the windows in my 1986 Silverton convertible and love the privacy. I also have a canvas cover that covers the three windows in the front of the cabin. The canvas does cause a lot of heat so I am thinking of trying the double mesh cover.
US Yacht Canvas in st. Pete. Bob Winkler good work, good ideas, good prices 727 322 5352
We do them Mike with bolth Canvas and screen mesh. not sure about Tampa but Clearwater Canvas is excelent.
canvas
Mesh
What are blue board panels? Are they similar to the mylar windshield covers for trucks and RVs?
No it's the stuff they use on houses. It comes in 4X8 ft. sheets. Get at the lumber yard.
I must be missing something. How is adding canvas going to "lower the cockpit temperature at dock?" It would seem to me that if you are going to cut off any some breeze that you would INCREASE the cockpit temperatures.
G
G
The idea is to block out the sun from the cockpit area. This enters thru the windshield in the afternoon (Boat faces due West). This is mainly to help when the cockpit is all zipped up. You can see some of the previous posts pics that have the windshield covered with canvas.
Thanks Bruce.
canvas
Mesh
Thanks Mike.
marykhubby,
When you did your tinting, did you use the DIY materials/kits that are available for home & auto windows? Did you do any other windows? I have the mesh covering too but would like to do more.
G
OK. I am sitting here thinking summer time and you are talking winter time. It is hard for me to think of full canvas at this time of year.
G
G
G
G it gets hotter than hell here in Florida, especially this time of year.
G
G, I expect the full canvas is for summer time use. Putting a solid or light-filter canvas on the windows will help reduce the temps in the cockpit by blocking sunlight. Since he faces due west in the slip, the mid-day to afternoon Florida sun is probably brutal. I'm in NY and there are times when try to rig up some sun-blocking shade to keep the heat off too. He might also be running AC to cool off the zipped enclosure and blocking the sun would be a huge help.
the second pic i posted greatly helped the cockpit AC,
