- Jun 4, 2001
- 4846
- 3,913
Drain the tank first Jim!!!!!
Mine has a garden hose bib on it and I hook a garden hose to it so I can use the air to force the water out thru the drain bib, out thru the hose and overboard. When I do this I keep the hot water side of the faucets closed so the air WILL push the water out of the water heater.
I don't drain my heater into the bilge.
If you don't have a hose bib, drain the tank out into the bilge.
Once that is done, close the drain then pump air thru the heater to blow out the hot water lines.
