Ok. I bought the adapter from Wally-Mart, drained the entire system, and used my little Black and Decker tire inflator to blow it out.
It was time consuming with the little compressor, but it got the job done.
I brought the system up to 50 PSI and then opened the furthest (galley) faucet. I had to repeat this a second time just to get it all out. I then kept bringing it back up to 50 PSI and worked my way back to the head, shower, hot water heater, and finally the fresh water wash down.
The biggest PIA is closing the system, and waiting for it to get back up to 50 PSI.
The boat is still in the water and should be coming out in the next week or two. When it comes out I'll finish the job.
I know that I can just leave it the way it is and it will be fine, but I'm a little anal and wouldn't mind the peace of mind the AF provides just in case there is water still in the pump or in the very bottom of the tank. Like I've said before; I never use the fresh water sytem for drinking and don't care what the water tastes like.
I have a few cases of the AF on hand anyway.
I haven't decided yet if I'll use 8 gallons of AF, turn on the faucets till it comes out, and then drain and recover the 6 gallons in the HW heater for use in the head and the bilge pumps. Or, if I'm going to temporarily by-pass the HW heater and do the system with just a couple of gallons of AF.
I did buy a HW heater bypass kit, but I don't think I'm going to use it. First of all I don't want to add any more conections than is absolutely necessary because every connection is a potential problem, and secondly the valves that came with the kit look a little restrictive and I don't want to lose HW pressure.
