- Sep 16, 2003
- 12212
- 12,200
i was really surprised to find check valves on ALL the 4 bilge pumps on that boat. Knowing how many express (and FB) that "well known buider" cranks out, i can't imagine that most surveors write up the check valves. it must be like, they're all like that, it's ok.
well it's not ok, because in this case, the only bilge pump forward of the engine room bulkhead wasn't working...
Fred, what about tinned wire? I thought it was also an ABYC standard that most builders followed? i found a lot of orginal factory installed plain copper wire on that boat. Interestingly, on the electrical panel side, you could see tinned wiring, but not on the business end like on the water pump or bilge pump.
