Update on Trawler refit
Originally posted by walterv
If you have a generator why have a propane stove???
It's a trawler thing, you wouldn't understand. :)
haha- sorry- couldn't resist. Actually a good question. Really- the goal is to just not have to run the generator and be able to anchor out for as long as possible, etc. Plus, one could get up early and make coffee, etc. and not wake others cranking up a generator to cook. Plus, just that much less fuel usuage, not that generators use much fuel!
plus, propane/gas is just much nicer to cook on than an electric stove. The downside is you could blow yourself up if you do it wrong. :)
Jim- my son would LOVE to be part of the vol navy and see a home game on the river!!
Tony, I have a traditional propane stove setup in my 1977 Californian and love it. We only use it a few weeks a year, but when we need reliable cooking for baking/stovetop use, it's always there without having to fire up a generator. We have the vented propane locker on the FB with twin bottles, so there's plenty of capacity. I also have the bottles available onboard as a backup to the small bottles on the rail mount propane grill.
I saw your post re: the washdown pump and have recently completed the installation of a recessed hose canister at the bow for anchor and foredeck washdown. I already had a wd pump T'd into the head thru-hull which was connected only to a cockpit hose bib. here was no need to install another thru-hull and I T'd into this 1/2 inch line downstream from the pump and ran it to the bow.
This was all part of a windlass/bow washdown install. I haven't finished the non-skid repair yet so no pics. I've been fllowing tis thread closely for tips on completing this part of the project. If it'll help, I can take some in a couple weeks when I'm on the boat next.
Al, I'd love pics of how you did your washdown pump. I actually have a washdown and associated 12V pump back rb2@gr5t the transom. I've never paid it any attention and haven't even seen if it works yet. I am going to see what is up with it next time I am at the boat this week and will see how it's plumbed....if pump is working or at least alreay raw water plumbed, I'll just T into that set up and install a fixture of somesort up at the bow for anchor washdown.
So you have a dedicated propane locker that is air/vapor tight? Most trawler owners seem to just mount a tank under the flybridge helm, making sure it's not venting down to the salon. The true storage lockers cost like $700!!
Tony,
Your right, I don't get it :) But I do, good for you.
Me,
I want all the modern conveniences, like not having an out house , indoor plumbing and electric ;)
outhouse...now THAT Is a good idea....eliminate the holding tank, plumbing, etc. Hmmmm.....I think you're on to something Walter! ;)
I'm with Walter on this I want all the comforts of home and the office on my boat, perhaps even more.
so what is inconvient about having a gas range on the boat?
Yes, my propane storage in under the FB helm which has stainless vents on the sidewalls, port and starboard. It is a secured 2-tank mount.
Having the wiring and switch for the wd pump is a great start, assuming it's in good shape. Even if the old pump is shot, like mine was, with good wire, it's an relatively easy and inexpensive replacement. I went with the Jabsco Par Max 4.0 Washdown Pump. Good pressure and not too loud. Seems to work well. I also added a lighted power switch at the helm to help remind me that it's on and needs to be turned off.
I'll be on the boat after 11/6. I'll get some pics of the pump, the T to the head raw water source, and the bow accessories.
If you have a genny and your only propane is the stove I would suggest electric if you have 220VAC available. If you only have 110 go propane as 110 electric is slow. The only downside of propane is the water vapor they generate in a closed cabin. If you need propane for the fridge, it's a no brainer. Go propane.
I was on Lanier just last night. RV park near Gainsville. Ashville, NC tonight.
On the stove, go with the propane. I took a perfectly good AC oven/stove out of my Albin & installed propane just so that I would not have to listen to that noisy generator just to boil water.
Nothing like having a decent battery bank, a decent inverter & the genny only when it is really needed.
With a decent inverter (we have a Heart Freedom 10) you can make coffee and toast without starting the generator. Coffee maker uses about 700 watts, ditto the toaster. You are going to need to run your generator sooner or later anyway to charge your batteries, that's when we do our cooking on the range. We also find that most of our cooking when aboard is done on the Magma grill, with a roll of foil and some foil pizza pans it is amazing what you can do on the grill. The 110v Princess range on our trawler does the job just fine for us, we do have a 20lb tank of propane for the grill, but that sits outside, no plumbing or solonoids to worry about leaking.
Personally, I love my propane stove. The 110v stove I took out just simply was too darn slow to get hot. Propane, turn it on and it's hot right away and cuts cooking time way down.
I do a complete inspection and leak check of all lines and connections twice a year just to be on the safe side. Use soapy water and a small paint brush to check connections.
LEDs give off far less heat than halogen or incandescent.
Get yourself a butane burner (about $50) to use to heat water, etc., when you don't want to run the genny.
BIG props to Billy!!!
He sent me a "little" gift in the mail today! I guess he wanted to be sure I could post here on boatered 24/7 whereever I may roam, so he sent me a Rogue Wave Wifi- says it can pick up a hot spot from 7 miles out:
Bill, can't thank you enough and as i told you earlier, I am going to pay the kindness forward! Now I can be sure and be able to always get a signal to check in on boatered...good for me, mixed emotions maybe for you all!! ;)
Kudos to BillyIII!! That's really cool. Gotta love BoaterEd!
Maybe a new thread on it's effectiveness once it's operating?
AHHH Billy is the best........
I have that set up Tony, works like a charm....... I use my VOIP phone with that setup....Billy is the king on WIFI advise.
Anyone that has had the pleasure to meet Billy gets the guy he is, wonderful, caring, knowledgeable person.
Thanks guys just so everyone know's my wife should get some credit we have been talking with Tony via e-mail and we thought this would be the perfect gift for his new project. Tony enjoy the unit and I'm sure your kids will think staying connected is cool as well.
Best,
Bill & Jan
I need to get me one of them, where's the best place Bill?
