Originally posted by Knotayat
It's not the nuts on the back. It's only that small phillips screw. I believe you have to lift on the lens cover, then pull after you get that screw loose.
Correct it is probably just stuck pull out and up from the bottom there are two small tabs on 5he top that it sits on.
Thanks for the advise. The small phillips screw at the bottom was stuck and became stripped. I was able to drill it out but it broke. It's a 3" long screw. I wound up buying a used light at a consignment store for the new screw and gasket. I was able to successfully repair from there.
